Anyone got a spare 2F oil pan?
Fort Mill, SC
I've had a oil drop for a while now, and now that it's on the road it's worse. Thinking it might be a rear main I pulled off the rear inspection cover and found it's really the rear oil pan lip. Pulled the pan and found someone in the past bent the rear lip and did a bad job of trying to straighten it up, using RTV to try and stop the leak. So I either need to straighten it better, or my preferred option is another straight pan.
The pan is still available new from Mr. T. I'd go that route before I spent the time and effort to install a used one. Over tightened pan bolts and popped spot welds are the usual fare for used 2F pans. Better off with new IMO.
Yep, good call. $233 shipped, not terrible.
Nate, here’s Georg’s thread on rear main seal and oil pan installation. If you follow it, you’ll have a leak-free reinstall. I know I did.
Thread 'F, 2F, 3F and 3FE rear main seal, oil pan gasket and clutch installation instructions'
F, 2F, 3F and 3FE rear main seal, oil pan gasket and clutch installation instructions - https://forum.ih8mud.com/threads/f-2f-3f-and-3fe-rear-main-seal-oil-pan-gasket-and-clutch-installation-instructions.1338727/
