Hello taking a trip to vermont to snowboard next week; has any one used tire chains for snow if so what brand i am still on factory tires so i should have no problem with them fitting (have an 06 lx thanks)
was going to order these from rud
http://www.rudchain.com/snow/grip4.htm
but i dont like using metal b/c if they brake lots of damage i seen somewhere there was a plactic version any ideas?
Chains have a max speed (20mph?). You also have practically no lateral traction...just forward/reverse, so they are not good on the wheels used for steering (like if you have front wheel drive). For some reason, out in the West like in CA, they always require chains on mountain roads. I guess that's because no one uses snow tires since it only snows in the mountains. M+S and AT tires really don't cut it for hard core snow. They are okay, but if you drive on ice, they won't help. You need either studded snow tires or a good dedicated snow tire like Blizzaks. My in-laws in Hokkaido, Japan (200 mi from Vladivostok) run snow tires on all their vehicles (sport sedan, 4wd suv, etc.) but the front loader, which is 4wd low only and has chains on big tractor tires. They've taken me on mountain roads with switchbacks in a rear wheel drive sedan from the earl 90's (i.e., no VSC/Trac) at speeds I would never have driven at given the conditions when I lived in Upstate NY...the car was always near the threshold of control going 35mph in 20mph conditions (if you had RWD w/ M+S tires only). With blizzaks on a 4wd, you can drive at amazing speeds. I guess chains would have an advantage in deep snow with 4wd going slow, like climbing over a snow drift or on sheet ice on a grade. Even on sheet ice in the flats, quality snow tires work very well.
As an alternative to chains, one could carry an extra set of wheels and install them when you hit the snow. If you have a dual pivot Kaymar/TJM bumper, you can put 2 tires there, then two inside.
Diamond style chains (RUD, Laclede) do offer lateral traction compared to ladder style chains.
