Any thoughts on this oil...
I’d run it. Meets the spec. For $15 per 5 qt that’s a great price. If they have it local I’ll definitely switch.
It is made by Warren Distribution Inc (same as Supertech and Amazon).
Bottom line, is it will work fine, but I prefer the EP M1 as it has more PAO, and I stock up when they have their rebates, which they send by email and I e-deposit. Pretty easy. Penn Platinum and Valvoline are both Group IV PAO Base stock, worth buying if you can find a sale!
Try the Kirkland stuff out and do a UOI!
I think pennzoil platinum is group 3. I might be wrong.
I'm sorry but an $85,000+ vehicle and your worries about cheap oil??? I have a 2016 and change my engine oil every 5,000 miles.... sorry, but for me its not even a conversion to have... plus I use a factory oil filter too!
No one said they were worried about anything. All I asked for was an opinion on some oil. Sorry you were so offended.
yep .. stay with good oil , this is very low cost insurance for your engine !
so.. mobil 1 or Toyota oil , no less !
Looks like it meets the specs so I would think it's fine ...
Mobil-1 0w-20 made for toyota .. which most the tundra folks with the 5.7 engine run is another option
You can order mobil-1 from walmart.com delivered free (just like amazon).
Toyota dealer use bulk non brand name oil in there oil changes daily.....0-W20 is only synthetic.
0-20 is no longer only full synthetic. Many brands now sell a conventional/synthetic blend in that weight.
I do every other oil change 5000 mile interval. I have been buying mobil 1 at Costco and have not seen that Kirkland oil in my store yet. The other oil change is done at NTB and they do alignment check and fix if needed as I have 3 year prepaid on that. I and NTB rotate tires. I use Toyota oil filter. NTB uses their stock 0-20W and filter choice. I am not worried about NTB or their choice of oil. I have been using 5w-30 what ever was on sale in my 22+ year old T100 and no issue to date. I change the oil in that every 3000 miles or once a year. For last 10 years or so it has been more of once a year.
My Opinion for what it is worth is change oil and filter regularly and you will have have very long lived LC. If I see that oil in my Costco I will likely buy it for my next change. I am averaging an oil change about every 4.5 months.
I wouldn’t hesitate to use this if it meets spec. Kirkland makes quality products — good examples are golf balls (the original Kirkland golf balls were rumored to be manufactured by Titleist with Pro-V1 characteristics; not sure about the current model) and their 18 year old single malt scotch is not bad either for $50.
