Any reason almost noone runs aftermarket wheels on 80's?
Someone posted on here..maybe C-dan...that the Japanese have a wheel standard on the 4x4 trucks that the tires have to be able to stay on the rim and hold pressure after a direct curb impact at something like 40 mph. I could have some of those figures wrong. But after reading that, I saw no need or advantages to changing rims over the stock OEM versions.
The Japanese have some pretty stringent standards for wheels. The standard that Toyota truck wheels are certified to is Japan Light Alloy Wheel Truck & Bus, the wheels have JWL-T on them.
The small backspacing and large diameter hub circle (4 1/8 or 4 1/4 I think) limit the available aftermarket wheels.
heres a little more on the testing standards for the rims off of acurazine.com
Here is a brief outline of testing to JWL spec:
Cornering Fatigue Test (Drum Endurance Test)
The purpose of this test is for checking wheel rim strength and durability. Place a wheel assembly with tire on test equipment. Radial stress is then added to simulate vehicle weight.
Test run 500,000 cycles
After 500,000 cycles inspect for cracks, deformation and any nut loosening.
Radial Load Fatigue Test (Rotary Bending Test)
JWL pass criteria: 100,000 cycles
The purpose of this test is for checking durability of the wheel disc. The spokes and the hub are the first point of weight distribution from the vehicle and spoke strength is gauged by this test.
Place a wheel on testing equipment and by adding bending stress to center of disc –
Test run 100,000 cycles
After 100,000 cycles, inspect for cracks, deformation and any nut loosening.
13 Degree Impact Test
JWL pass criteria: 594 kg
The main purpose of test is for checking strength between rim and disc cross section. The “joint” or the area where the spoke and the rim meet is an important structural area that is subject to great stress. The horizontal weight of the rim and the vertical stress of the spokes meet at this joint and proper structural stability is crucial for a proper wheel.
The wheel assembly is placed with tire tilted 13 degrees from horizontal plane on testing equipment.
A preset weight is dropped on the outer sidewall of tire, thus giving impact to the wheel/tire. Then inspect for cracks, deformation and air leak.
This test is very important for the recent trend of a larger/wider wheel with lower profile tire combination, because there is less air volume than OE wheel/tire and more stress to inner rim section. This test simulates actual usage condition such as hitting corner curb or objects from side.
