So I've been looking all over and I apologise if I overlooked the answer to this question, but has anyone ran or know if a 255/75/17 8.5 -22 offset fit a stock 2005 gx470 with minimal to no rub? Want to run the largest tire I can without having to trim anything or at least very minimal trimming.
I was going to run the stock rims on the 255/75 but I found a rim I like Black Rhino Sandstorm in a 17 8.5 -22 configuration. Was going to run 265/70/17. However I think I like the skinny look better. Also, I would be able to run both sizes on the 8.5 if the skinnys don't work out. That rim is also available in a 0 offset which I am sure will fit with no trimming and I could always add spacers to get the poke I'm looking for. Would like to stay away from spacers if possible and thus the question if the -22 is too much to clear from lock to lock.
I was back and forth between kenda klever RT, wild peak AT3 and Grabber X3s. Although the X3s are the only tire I have found available in the 255/75/17. So looks like the X3s on this package if the -22 will fit.
Any advise would be appreciated or if anyone is running a similar offset/combo to show exactly how far the tire will poke outside the wheel well at -22. Thanks!
