Can you list the part numbers used? thanks
thanks for your thread! Just ordered the leveling washers. The gutter clamp should be bolted from the top as it interferes with opening the damn door!I still don't like the bolt from the bottom though, and I'd rather have the anti corrosion protection of the stainless bolt. I believe the chances of the bolt ever failing, or at least being the first point of failure are less than zero.
thanks for your thread! Just ordered the leveling washers. The gutter clamp should be bolted from the top as it interferes with opening the damn door! View attachment 1538765
I only have this clearance issue on the front 2 mounts - above the driver's and "shotgun" doors. The other 6 mounts are not above any doors. Just reverse the bolt. Head up, instead of down. Thread nut on bolt all the way to the top of bolt, to use as a locking nut. Fitting welded to gutter bracket becomes the bottom nut and eliminates clearance issue for front 2 mounts.Can anyone provide a parts list / upgrade for the mounting hardware? Rack itself is great but from reading this thread, mounting hardware has actually gotten worse….
Sorry for pointing this out, but I think your rack may have the right/left sides swapped.I only have this clearance issue on the front 2 mounts - above the driver's and "shotgun" doors. The other 6 mounts are not above any doors. Just reverse the bolt. Head up, instead of down. Thread nut on bolt all the way to the top of bolt, to use as a locking nut. Fitting welded to gutter bracket becomes the bottom nut and eliminates clearance issue for front 2 mounts.
As shown from a previous pic in this thread:
Courtesy of @SupraTuRD (Post #20)![]()
Your perception of the sides is correct - ) ( , not ( ). However, the pic in my post is not mine. I was using it as an example of gutter clamp hardware configuration. I agree that if the sides were assembled incorrectly, the gutter clamp issue that is being discussed would be even worse than it is. To be honest though, if the sides were incorrectly swapped, I don't see how you'd get them down in the gutters without tweaking the rack severely or loosening the crossbar bolts.Sorry for pointing this out, but I think your rack may have the right/left sides swapped.
This happened to me when I first assembled it, and it looked like your picture. The bolts also didn't quite angle correctly like yours. Unfortunately, the instructions did NOT mention right and left sides, so I had 50/50 chance of getting it wrong. Lot of work and some scratches to the roof to redo it, but it was worth it. Fit much better the correct way.
The side rails angle in a bit, then go vertical. See picture below.
