Felt like I had to start a new thread to get some help on this dilemma. I read through the thread Shocker directed me to but could not find the info I'm looking for. I have two questions.
1. Can anybody tell me exactly how much you can expect the rear axle to shift to the right with a 2.5 OME lift on? Has anyone with a 2.5" lift measured the space difference between the frame rails and the inside of the tires? If so what numbers are you getting? If you lift your truck 2-2.5 inches then does it make sense that the axel will be shift over to the right approximately an inch or so or am I over simplifying this? (I really need this info before I pursue this post-collision repair inspection discovery any further, as I'm beginning to suspect my trucks always been that way as C-dan has suggested. I just need some confirmation or comparison figures)
2. It's never mentioned, but ideally would it be worth it to get the adjustable panhard from Christo to move the axle back in line even with the 2.5" lift to try to bring everything back in line?
