Thanks for the response. Would the older gauge work better/be more sensitive with the later wiring than the later gauge?
Thanks, Taro
The older gauge is more sensitive, but lower capacity.
Whether that is better is up to your judgement.
Clarification please: I was under the assumption that the newer ammeters were sending a minuscule amount of current to the dash because it was measuring a voltage difference and "interpreting" current vs the older style meters that were actually inline between the battery and alternator.
If this is so, would it matter if the later wiring was hooked up to the earlier gauge as it wouldn't actually be receiving +/- 30a (for the older meter)? Thanks, Taro.
...Btw--a bit of trivia ... what made me realize that my gauge was not stock was that on the '82+ ('79+?) the odometer was supposed to have an extra digit that I didn't have (thanks to Merle and Glen @ Classic Cruisers for this information). Then it made sense as to why my ammeter read +/- 30a
Thanks again!
btw-lostmarbles, apparently the odometers with the seven digits are pretty valuable/rare in the US--asking price was $300-$350 US vs $150 for the six-digit odometers :O
Holy thread revival!
Just out of curiosity, is it going to affect anything if I remove the ammeter from the circuit completely?
Reason I ask is that I've found an aftermarket ammeter that will fit almost perfectly where the OEM one fits.
If I mount it in the same spot, all I need to do is cut the negative track on the back of the cluster where the ammeter bolts to and then run a single cable to the alternator.
Edit: 1982, internal shunt 50A gauge cluster.
You are the man! You have saved me a couple of times and this one is great advice also. I ran the tests and it it appearently fried. I sent you a picture of the gauge. It looks as if the solder points inside the gauge at the inside of the studs once had something hooked to them. Am I correct? Thanks for all your helpThe ammeter is a shunt type. In other words there is a metal strip with very low impedance (resistance) where the actual meter reads millivolts (induction) which are translated in amps on the scale.
So if the (resistor) strip is ok and the meter is broken, the charging sytem will work but the reading is zero.
The resistor strip is something close to 0 ohm. See pic below.
So; how to figure out if the ammeter is ok or not.
Meassure between ground and the + of the ammeter (key is in on position). There should be 12V.
The same for ground and - of the ammeter. there should be 12 V.
Now switch on your headlights and meassure between the + and the - of the ammmeter. You should meassure a voltage drop of less then 1 Volt. If this is so the circuit is OK but the meter itself is kaput.
If all you readings are 0 but the battery is charged, it means that the ammeter is bypassed somewhere.
Good luck.
Rudi
