That pc is the inner shell just ahead of the door hinges...thought it would be recognized, my bad.A brief description of what we are looking at might be helpful.
Negative for antenna mount, that's on the other side.Might be the bracket for a power antenna
EDIT: inner shell, gimme a minute...
bracket for the blower motor?Negative for antenna mount, that's on the other side.
Not for this one at least.bracket for the blower motor?
Nope, someone has the answer hopefully.Hmmm. Does the (steel) dash frame bolt up to it? If not, I've struck out.
Good luck!
Nothing this evening, next few days or so is fine.How badly do you need to know? I have a stripped cab out in the back yard?
Affirmative.I checked the cab on both sides there's no bracket like this. Is this on the inside of the cab?
Would that be different from this?pretty sure that's where the Circuit open relay goes.
nope guess I was wrong
Close, but no cigar....nope guess I was wrong
Rumor has it antenna mounts to the other side of this panel.it would be the antenna bracket if a RHD ...
or vise versa if that is a RHD ...
