Having to 'lock' it twice to get it to lock is not how it should be. I suspect it's still a bit sticky. I wouldn't use WD40 in a lock. It will dry and leave residue. I'd use a sh*tton of dry graphite lock lube instead.
On a side note: IIRC, the entire mechanism (handle, lock, etc.) is the same on my '76 FJ40 ambulance door as the passenger door mechanism on my '71 FJ40. Has anyone else noticed this? Or am I going senile before I can even start getting Social Security?
Seriously, Eddy, a sh*tton? It's just an itty bitty lock!
Your lock is installed 180 out. You can insert the lock into the door but the relationship between the key position and the square drive that engages the inner handle is what is messing you up. I saw earlier you asked if there is supposed to be a little lever for lock/unlock and the answer is yes. I made mine from a piece of hard wood as the "new" paddle handle lever broke shortly after installation, little piece of plastic.I cant seem to lock her up manually from the inside, could the lock mechanism on the inside, not the cylinder be the problem?
Lock and Key This picture from Cool Cruisers shows the "correct" orientation of the lock cylinder.The teeth go up and the cover rotates to the right to allow access for the key. The cylinder just turns around and around as I recall but will only install in one of two positions. Like you, I could get the thing to lock but then couldn't remove the key. So I found that I had to rotate the mechanism 180 to get it to work right.
