r2m
Richard
Hey All,
I haven’t posted in some time on account of a full time job, full time student and being an Army officer reservist with a unit of soldiers under me. Needless to say, I have no life. But I WILL someday again. So even though I’m completely re-geared, I have to wait 1000 miles for break-in and then find the time to try everything out! All geared up and not place to go!
Anyways, regarding the meat of this post, just had my ’98 100 Series (with factory E-Locker) completely re-geared. Here’s the story:
1. Front and Rear diff gears
· Manufacturer: Nitro 4:30
· Distributor: Just Differentials
· Website: justdifferentials.com
· Phone: 866.349.6801
2. Front air locker
· Manufacturer: TJM
· Distributer: Just Differentials
3. Transfer case re-gears
· 3.116:1 Gear set (replaces the 2.488:1 factory transfer case gears). Almost 75% total gear reduction (with torque converter).
· Manufacturer: Marlin Crawler
· Distributor: Marlin Crawler
· Website: marlincrawler.com
· Phone: 888.942.7295
4. Compressor
· Manufacturer: ARB
· Model: CKMTA12; On-Board Twin Air Compressor, 100% Duty Cycle, 12Volt
5. Locker switch
· 80 Series factory Front and Rear Locker rotary switch to replace the factory 100 Series Rear Locker (only) rotary switch (the rotary switch just left of the steering column on the lower dash). Added small rocker switch to turn the compressor on and off just above the rotary switch.
· Manufacturer: Toyota
· Distributor: (I forgot who I purchased the switch from. It was from a Ih8MUD vendor. Just can’t remember who.)
6. The shop that did all the work was UniTrax Drivetrain Inc.
· Website: gounitrax.com
· Address: 1280 N. Sunshine Way, Anaheim, CA, 92860
· Phone: 800.622.4327
NOTE=>> I have to put out huge KUDOS to the staff at Just Diff’s and the staff at UniTrax for making this happen! I’ve been slowly purchasing all my components over the last year, plus. I installed the ARB compressor, switches and everything just fine so the only thing needed was to get all my gears purchased and installed. Somewhere along the line, parts for the TJM Locker came up missing, either from my partial install a year ago or perhaps from the manufacturer. I also needed new front half shafts and birfs. I saw the half shafts and birfs when I picked up my rig and they truly were trashed.
UniTrax and Just Diff’s worked together to get the missing parts so they could finish the job. UniTrax also sourced out new half shafts and birfs at a fraction of the cost of Toyota OEM parts. I could have been totally taken to the cleaners on this job if it wasn’t for Just Diff’s and UniTrax. I highly recommend Just Diff’s for your gears
and if you’re in Southern California, have UniTrax do the install.
Please check out their websites and NO I’m not getting any swag for this post. It’s just the truth.
Forgot to note I'm running 35" tires with a 2" suspension lift and 1.75" body lift (3.75" total lift). Also, the re-gearing COMPLETELY reset my speedometer to almost dead on! At 75mph, my GPS says I'm doing 74mph. I can live with that! At lower than 40mph, there is no difference between my speedo and GPS readings.
2. Front air locker
· Manufacturer: TJM
4. Compressor
· Manufacturer: ARB
5. Locker switch
