You're green, and if it's not rubbing, I'd rock it. Given the level of total f**ktardery in the alignment business in your area, I wouldn't trust any of them to do anything else. I don't even believe the numbers on your printout, actually. The "before" measurements in post #40 don't even come close to the "after" measurments in post #24. They should be close to the same if no one has dorked with the alignment. Which one is telling the truth? Your steering wheel misalignment lends credence to the Toyota shop, but they "should" have been able to much, much better with the OEM UCA's in the first place.
"Could" you get your wheel centered in the wheel well? Absolutely, in an hour - with a compentent shop. Given your experience, if it's not rubbing, let it be. All they have to do is rotate LCA forward to max, and then rotate the SPC UBJ one notch forward to dial caster back down to spec, slide the UBJ in/out to dial camber, tighten to torque specs and send you on your way. You have encountered no one that has shown capability to do that while simultaneously taking your money as payment for services rendered.
Truck probably drives great as-is at speed, yes?
