Need some advise from the knowledgeable people on the forum.
I've driven lifted trucks (40s, 60s, 70s and 80 Series) my whole life. But this is my first time with a 100 Series so "IFS behavior" is new to me.
It's a 2003 Land Cruiser on 275/70 R18 BFG AT KO2 tires with about 1.000 miles on them on the OEM (tired) suspension.
I installed a Heavy lift yesterday:
Droop at the front is at 1.5 inches (38mm) instead of the recommended (2.1 inches / 55mm) because an ARB Sahara front bumper and winch will be installed (hopefully) next weekend, so the extra weight might put the Droop in recommended specs, if not, I'll adjust the torsion bars a accordingly .
So I had the truck aligned this morning at a local shop (just picked the closest one to me). After it was done, the steering feels (very slightly) harder to turn than it was prior to the lift (same tires). And there is some wandering on the road. Very minor, but still noticeable. Different to how the truck behaved with the stock suspension and different from what I know from my former solid axle trucks.
I asked for the alignment numbers and some values are off spec. The tech said he cannot correct the values any more as they are already maxed out...
Should I ask for a different tech ?
Should I try a different alignment shop ?
Or is he correct and a lifted IFS truck will have to live with some values out of spec?
Maybe lowering the front to the suggested Droop measurement will help get the alignment values in spec?
I was under the impression the UCAs would give the option to actually attain ideal caster and camber values... Maybe the tech does not know how to set these UCAs ?
Here's a copy of the values.
I appreciate your comments!
- OME Nitro Shocks
- OME Torsion Bars and Springs
- Slee Diff Drop Bracket
- SPC Performance UCAs
