afgman786
Looking for help on getting to the root cause of my right hand pull. I feel the pull the most when engine is under load, very noticeable when towing compared to not since I don't stress the engine as much normal driving. I just got alignment done again after installing bumper hoping that extra weight on the front end might help the issue.
Questions/Thoughts:
1. Asked the dealer to dial in caster to around 3 since I've got the bumper now and push away from rear. Tech was having issues with driver side and couldn't get it lock in at 3.0, I did not have them mess with adjustment settings on the SPC but try and adjust within the setting it is at.
Could the extra 0.3* on driver side contribute to still have the right hand pull, also feeling it more now than before I went in.
2. Driver rear toe is up there, could the rear LCA affect rear toe? If so then I understand why one side is at -0.23*. Also the pull doesn't feel like the rear end is walking out but the front end is pulling right.
3. What should I have the dealer try since I still have pull? Is there other components I need to look at?
Questions/Thoughts:
