For Sale Alberta Canada HZJ79 Ex-Mine Truck Parts
Edmonton, Canada, T5E-5R9
I recently bought 7 HZJ79 mine trucks and while I am trying to sell the better ones as wholes, I know that I will have to sell some as parts, maybe all, so I am also posting here.
I have sold one body locally so I will have a 1HZ engine to sell for sure. All trucks have A02B full floating rears (5 bolt), 1HZ Engines and R515F Transmissions. Lots of parts look to be recently replaced as well, like gas tanks, axles, brakes, rads...
All transfercases are locked in 4Lo and some of the transmissions do not run through all the gears while there are a couple that do and are driveable.
Unit 520
Unit 685
There is too much to list so feel free to ask questions.
Interested in the 1HZ engine. If you end up having more than one I might take that too
price?
Potentially interested in a transmission and transfer case combo. Got any more info on conditions and prices of the different ones you have? Also, do you have any idea what shipping would be to Minnesota?
Thanks,
Travis
Unit 520
View attachment 2616462View attachment 2616463View attachment 2616464
Unit 685
Unit 520
Unit 685
do you have functioning transmission still?
Please get photos of actual part before completing purchase. Not to beat on seller, just mine stuff and especially aluminum parts run through a hard life. VERY, VERY HARD LIFE.
As I have said before, I parted a 750 hour (very young) 75 series truck with Greg Riemer in 2002 from a hard rock mine (not a potash mine at least) . The engine, after replacing all small parts with new (water bungs. heat shields, injector tubing, freeze plugs) ran well but still had corrosion.
The rest ended up being sent to dump. Both birfields were exploded for at least the second time. Bellhousing had to be broken to pieces with sledge as it would not back out. The t case was 1.99:1 standard and pretty worn and the aluminum shell was junk. 40 plus pounds of silt was in the frame rails. The fill float was already speedy sleeved and had 1/2" plates welded over the axle tube so the newer U bolts would not pull through. The truck was sold because early on it ran into something and cracked the frame front crossmember. On disassembly, the first intact x member was the rear shock tube leaving that and rear x member holding frame together. motor mounts, spring mounts, transmission mount, center tube were all cracked 100% through.
Buyers beware of any and all mine truck surplus non new old stock.
@HoffLarr I am potentially interested in one of the 75 series. I saw an image of one with a flin flon mine sticker. Are the trucks from the Flin Flon mine? i have had alot of family work and are from there so would be cool to have the connection.
