For Sale Aisin short body hubs set 1
74HogGuy
Lifetime Rookie
Fayetteville, Arkansas
Purchased a new set and no longer need these. $110/shipped USPS flat rate to the lower 48. I also have a new set of OEM hub face hardware to go with it.
Do you still have these hubs? I have a set of 71 axles on my 77LC. I'm interested if they will work.
They likely won't work, if your birfs are the original coarse spline birfs.
@Ted Kush - What Stump said. These hubs are for those who have upgraded to the larger pattern knuckles and shorter fine-spline birfield.
Justin
Stumpalama 74 HogGuy. Thanks for the input. Below (hopefully, I'm new to Ih8mud) is a pic of my hub. It is a 12 spline. If your hub will not work, any suggestions. I have the drivers side, just not the passenger side.
@Ted Kush - you definitely have coarse spline hubs. My recommendation is post a want ad and someone will almost give
you one. You'll eventually want to upgrade to FJ60 knuckles and disc brakes. Then you'll be able to run fine spline birfields and hubs.
- Justin
Bump...still have these laying around. Need cleaned up and reassembled. Make an offer.
