Hi, I am new member to this site and want to ask peoples exeprience with K & N air filters vs. OEM.
Thanks
OEM filters much better than K&N
I've run K&N's for the last 15 years or so. All of my vehicles run them without any issues.
As for performance increases, it's probably a little but not earth shattering. I like the ability to clean and re-use a perfectly good filter. They have saved me a lot of money over their lifespans.
Adam
I started smearing a thin layer of clear grease on the inside of the intake tubing (just a small area). I've never found any discoloring or grit on this grease.
my .02
Adam
that is a valid argument DMX for the aftermarket intake kits that K&N sells. For the drop-in filters the paper/k&n see the exact same amount of dirty air.
paper always works well the other stuff is hype....
Partly BS/hype - they claim it flows more air, and that it does.
In the past 12 years, I've lived in Oregon, Texas, Colorado, Virginia, Colorado (2nd time) and now Ohio.
That pretty much covers the climates of the U.S. so I've seen my fair share of salt, sand and dust. After a week of solid off-roading in Moab, with my Jeep, the K&N looks pretty nasty on the outside, but it is as clean as can be on the inside which tell me it's working. I just cleaned two of my K&N's this past weekend so I clearly remember what they looked like.
I'm an engineer by trade, I wouldn't run them if they didn't work and keep the dirt out. There are a lot of naysayers out there, but I've done my homework on this one and I'll be keeping mine.
I learned long ago to only believe half of what people tell you. It's up to you to figure out which half to believe.
I'm not sure what OEM filters cost, and I'm sure they do a great job (they are Toyota after all), but I'm also confident that K&N's will save me money in the long run and will do just as good of a job.
As for the concern about oil contamination, I don't keep oil beyond 4000 miles before changing it out. I'm not a big fan of extended oil changes and I've never had an engine related failure in over 500,000 miles of driving in my vehicles. I tend to keep them up to and beyond 200,000 miles before getting something new.
As an aside, here is a list of vehicles I've had K&N's on:
81 Subaru Sedan (real chick getter) Drove it to 187,000 miles. I started autocrossing it and took the heads off to inspect the pistons. I could still see original cross hatching on all 4 cyclinder bores at 181,000 miles. This is why I'm a big fan of frequent oil changes. I changed oil every 2500 miles and drove the tar out of this car from age 16-27. I then loaned it to my brother and he trashed it.
1991 Honda Accord, Sold at 191,000 miles to get the LC
1984 Toytoa Turbo Diesel PU 220,000 miles
2001 Jeep Wrangler 81,000 miles
1999 Toyota LC 89,000miles
Adam
