Air Filter Enclosure Gasket Help
DrRock
Kent, CT
Hello All, I’ve sent my air filter enclosure out for powder coating and as a result the seal that goes around the top, outside perimeter I had to remove. It was pretty shot anyway but now I need A new one. Does anyone know if there is a Toyota part number for this and if not, what have you used as a substitute?
Cheers, James
FJ60 or FJ62?
The air cleaner housing is radically between the two
I am interested in this as well. I have a FJ60 Oval. I did the same think but my seals were reusable barely. I was wondering if there is a rubber seal size you could use and just cut to fit.
Hello All, apologies I should have clarified, this is for an oval 1985 FJ60. The seal looks like it’s triangular in profile. I’m going to look around on McMaster to see if there is anything that might work.
Cheers, James
Cheers, James
You want this stuff — 5ft of it:
Trim-Lok X1333BT
It works great.
See this thread on Mud. In my previous life I was Output Shaft.
Also see my previous thread above it.
air cleaner gaskets? - https://forum.ih8mud.com/threads/air-cleaner-gaskets.802001/#post-9410767
