air cleaner bolts
The Sunshine State
ok i have a loose whatever somwhere under my hood that makes my rig run like crap SOME of the time... ran perfect last 3 start ups than bam ran like crap agian... so i did the fonzy thing and hit the air cleaner bolts (ya know the ones with the wing nuts) with the end of a hammer and the idle shot up to what it was suppose to be (choke out) so i could push the choke back in. last time i hit the coil and it worked, no go this time so i went tapping around with the hammer...and the hit the air cleaner bolts.. NOW is there somthing under that would stick? i dont know of any wires under there? would it be a stuck valve?? that would become unstuck when i would slam the hood? only this stuff does not work all the time ( the fonzy approach)
So is there somthing under there ... any idea would be cool...
thanks agian...
-al
Any chance the carb throttle linkages are gummed up? I'll also second the fuel cut solenoid. If its not that, it could be a partially gunked up passage in the carb. Check everything else, then get the carb rebuilt. Do you have a vacuum gauge? They're cheap and can really point to the source of a problem.
