yeah can be hard to restart on a hot day if it sits for a bit after running say an hour, sits for 10 minutes.
BUt that being said the carb is not so hot to the touch nor is the lines ( the base is a little more hot. )
And the temperature is like 80 degrees out, not in the 100s or anything. That is why i was wondering if a large amount of air was working in the system on shut down, and the system was trying to overcome that on restart, be it hot or cold... Of course I could be totally off my hat lol
I pop on a inline filter later today after a few work meetings, and see if it alleviates the problem.
I will def post back.
But yeah the heat soaked restart does have the "boil off symptoms" fluctuating idle rpms / vacuum, like 550- 800 rpms, about 2 second cycles or so. I am hoping this is just being caused by the extra air in the system creating a mixture or pockets of aerated air, making a lean rich senario until it burns off...
lsit of new stuff btw
new tank
new sending unit
new gas cap
new lines
rebuilt carb ( sorted out the accelerator pump issue, jet pumps a nice stream now )
new points ( gapped at .0016, dwell/ cam angle at 43 degrees )
timing at 7 degrees before top dead center ( stock on the needle )
I post back later!
Any insights welcome
afterthought, would not the mechanical fuel pump create a a prime that would prevent and fuel back flow?
pump is new too, only 10 thousand miles on it.
