Yesterday fellow member came at my home and tried installing tech stream but we weren’t successful. So he plugged his laptop with my cable and it worked out. We saw the fault codes. C1751 & C1762. At that point accumulator pressure was 8.9.
After he left I tried to bleed the system. With the ignition off, I bleed driver side rear. I also filled up reservoir with another 1000ml (one full bottle). Then tried to cycle it from L to N but nothing happend. Heard the pump running then stopped and finally with OFF flashing. Then I did drain all fluid from accumulator and tried to cycle but nothing drawing from the reservoir to accumulator. Then I moved to driver side front globes. Took out all the fluid. I even tried with accumulator while open the bleed valve and started the engine but nothing was coming out of bleed valve. I ran out of time and didn’t touch passenger side. I also found pump assembly was getting hot while trying to cycle it multiple times. My reservoir has fluid way up there from max line but nothing going inside the system. Should I buy new pump assembly. What can I try at this point?
It is very important to be sure that bleeding is good and that the problem is not caused by air somehow entering the system and remaining there from the previous effort at bleeding some time ago, just before these problems started (your Post #269 and Post #276). As described by @aharlan001 earlier in this very long thread and by others elsewhere, removing reluctant air can take many bleeding efforts. This means repeating the
@PADDO process but using ALL five bleeders one by one and allowing the engine and the AHC Pump to run to push fluid through, but being
very careful not to allow the fluid level in the tank to drop to empty and allow even more air to enter the system.
When air becomes "stuck" in the Height Control Accumulator, or in the Shock Absorbers, or in the long pipes from the pump to 'globes' and shock absorbers, it is difficult to shift. In such cases, bleeding from each of the four bleeders near each 'globe' is important, not just from one side. This is because when there are difficulties, the location of the air cannot be assumed and the air must be given every opportunity to escape.
It is also important to ensure that the Height Control Accumulator is filled and that bleeding takes place when it is full. The Height Control Accumulator only refills after a raise from "LO" to "N" or "N" to "HI". This can be difficult and may take multiple efforts of trying to get the vehicle to lower then raise.
Bleeding is not complete until there is good flow with no bubbles appearing from all four bleeders near the 'globes' and from the Height Control Accumulator, with no froth in the container used to catch the fluid. If nothing or not much comes out of the Height Control Accumulator (should see at least 300 millilitres or a good cupful), then this is unsatisfactory. It means that the Accumulator has not been filled with fluid -- it needs to fill and then bleeding has to be done.
When and if convinced that bleeding is good and the problem is not a due to air in the system, then it is time to consider problems at the AHC Pump and whether or not the AHC system is building sufficient pressure. The low Height Control Accumulator pressure of 8.9Mpa (should be around 10.5Mpa)
may be indicating a problem with pump pressure -- but as already mentioned, this Height Control Accumulator pressure also can be caused by air in the Accumulator.
If proceeding down the path of examining the AHC Pump, suggest first test the Pressure Sensor as a prelimary step even though DTC C1718 is not reported.
Then review the attachments for
C1751 AHC Pump & Motor Circuit
C1762 Fluid Pressure Abnormality
In each case, decide whether the symptoms you observe on the vehicle correspond with the description under the heading "Fail safe Function" listed just below the table on first page on both of the relevant attachments.
If the conclusion is suspicion about a partial blockage in the AHC Pump -- such as at the small screens/strainers inside the pump impeding pressure and flow -- then it becomes necessary to depressurise the AHC system and remove and inspect the AHC Pump.
Suggest review the information at Post #273 by
@Dref and also the information and especially the links within my Post #280 and also the information and link at Post #282 by @ktmracer01 -- all in this thread. This information describes how to remove the AHC Pump, and also provides comments about inspection and cleaning of the pump or its possible replacement.
See also similar information at Post #10 at this thread:
This is an attempt to explain how I removed and replaced the AHC pump with a few pictures to help. Tools needed are... --10 mm deep socket (for bolt under reservoir) --10mm wrench --10mm crowfoot or small 10mm ratchet would be gold for other bolt holding reservoir --fluid extractor hose and...
forum.ih8mud.com
Hope this helps.
