AHC, Actual Height, Pressures - LC100 (1 Viewer)
Azi
Sydney, Australia
Hi all,
I bought my first Toyota LC100 month ago and I spent all that time reading, trying to fix my AHC suspension. Coming from a BMW world that was a lot of information for a new guy!
The car is absolutely stock 2000 4.2TD LandCruiser /400000KM ODO/, equipped with 285/75/16 BFG AT KO2 in stunning condition for its age. Everyone in the family likes it and fell in love from the very beginning.
Every single gadget in the cabin works like a charm, including the height control - it is going up and down flawlessly, but it rides bouncy, springy - really don't know how to describe it. When I drive by speed bump the entire front of the car keeps going up and down for a while and takes some time to calm down. That makes the car uncontrollable and extremely uncomfortable for the passengers. The comfort - sport switch works, and it makes a significant change of the ride but doesn't help for the bounciness. Out of the town and highway, it is somehow better, but city driving is a nightmare, so I am looking for assistance.
I went already through the fat thread in the forum (Definitive list of AHC maintenance items) twice and through every single AHC thread that I found - really helpful information and I am very thankful to the community of ih8mud, but still need help.
Let me tell you what I did 'till now:
I started with a flush at the dealership - no luck;
Fixed the height sensors - no luck;
Installed new OEM AHC coil springs (black with purple) - drop the pressure a little, but still out of spec - no luck ;
Cranked the TB - no luck;
From what I read, I know that I have to start with TechStream to check the pressure and keep an eye out on the height.
So here it is:
Everything looks good, except for the rear pressure, so I ordered 30mm spacers, which I am awaiting - hope that they will drop it down a bit.
BUT...
When I measure the car with the tape from the center of the hub to the fender I get some weird data.
There is a difference at the front. The front left is lower than the front right by 2cm.
FL: 49cm | FR: 51cm (conv. to inches: FL: 19,29" | FR: 20,07")
and the situation is the same at the back, even worse:
RL: 52cm | RR: 54cm (RL: 20,5" RR: 21,25")
Both front and rear height sensors are mounted at the lowest possible point, so I tried to play with the nuts.
According to the fat forum AHC thread, when I distance the top and bottom nut the car should go up and vice versa, but I noticed the opposite and still not able to get at the actual height: 19,75" front 20,5" rear.
Here a question comes to my mind...are the stock height for LX470 and LC100 the same - 19,75/20,5"?
I am stuck on how to fix the difference in rear height. There is only 1 height sensor and there is a significant difference between the two sides...How am I supposed to fix that?
Also, another question, at the current height - even far from what it should be, I am getting ~4 graduations. I know that lower than 7 marks mean worn spheres, but my pressure looks good and ride is not harsh - totally opposite, could call it springy/extremely soft/weak - does that still means that my spheres are shot?
Please assist, because I am really about to give up and switch to regular suspension.
I really like the car, but this springy ride is killing me...
Cheers,
Azi
Hi, I didn't see in your post what exactly you did with the torsion bar bolts, but one of the strategies to even out the front is turning the torsion bar bolts in opposite directions an equal amount of turns. The first two values on techstream FL and FR height control sensor should be as close to 0.0mm as you can get them (right now you're at 2.0 and -2.2). Evening out the front may help with the rear being off.
I would start by getting your front heights as close to even as possible by turning the torsion bar bolts opposite each other, start with 1 full turn on each and then check. I believe clockwise will raise, and counterclockwise will lower, so make your adjustments accordingly.
As you know, 4 graduations is considered time to replace accumulators. Good luck!
Thank you for your input!
What I did to the TBars is I cranked them with few turns, till the front pressure gets in spec. I cranked them equally.
I am trying to get my front height in spec, but it is not an easy task. I reached the lowest position of the mount points and I start playing with the nuts - it's a mess...
In regard to the graduations - yes, I know that this is low, but they still keep good pressure - almost in spec. Does that mean anything or still could be shot?
Azi
Azi
To cross-level the front suspension you should turn the torsion bar bolts in opposite directions. I leveled my vehicle without ever touching the sensors. Cranking the torsion bar bolts in the same direction to get the truck into spec is supposed to happen after you cross-level the truck by cranking them equally in opposite directions.
Here I get confused.
What do you guys call "get in cross level"
Get it equal measured with a tape, or the information shown in TechStream?
When I was at +2mm /-2mm the tape was actually showing ~20mm difference (FL: 49 FR: 51cm) ...
With the vehicle off, cross level it right to left by adjusting the torsion bars. Measuring from the bottom lip of the wheel is easier for me than finding the hub center, and for this purpose the numbers don't matter, they just need to be equal. Crank clockwise to raise one side, counterclockwise to lower using equal turns on each side. I hit the AHC OFF button and drove it around the block to settle things between adjustments until I had it perfect Right to Left.
Now, the front AHC Height sensors seem to operate by taking an average of the right and left side sensors. Someone can correct me if I am wrong on that. I set them both in the midpoint which should be roughly 0.0 on Techstream, and then started measuring and adjusting. Here you need to measure from the center of the wheel hub (dust cap in this case) to the fender, you're looking for 19.75" hub center-fender. I adjusted both sides equally in small amounts until it was right on. Techstream showed +/- 0.2 or so, close enough for me. Set the rear height (only one sensor in the rear, easy) to 20.5 hub center to fender and THEN start adjusting your pressures to spec using Techstream and cranking the torsion bars, looking for 6.9 +/- 0.5 up front, and 5.6-6.7 in the rear.
My rear height was too high when I started. Adjusting to the proper height actually made more difference in the numbers than new springs did. Obviously if the hydraulic system is holding it too high, that is taking load off your springs thereby increasing pressure in the hydraulic system
Thank you @slus!
Here other questions come to my mind...
1. Does the front side to side height correction will help to the rear, cause I have an obvious difference at the back - driver's side sag?
2. How am I suppose to get the rear lower than the current level, as I am already at the lowest possible point at the sensor' slider and still higher than the spec?
Regards,
Azi
Thank you @slus!
Regards,
Azi
Hi Azi,
You seem to have made good progress since I last replied to you with the summary and attachments here.
Maybe you can guess, I am stuck indoors due to COVID-19 warnings. I must apologise for having too much time and for writing long posts in too much detail.
Due to some misunderstandings there will be some rework to do. Don’t worry about that. We all have had to learn-by-doing and benefitted from reading other experiences on IH8MUD. I admire your efforts to give more life to a LC100 with AHC and which is 20 years old and travelled 400,00 kilometres.
It is not hard to correct things from where you are now – but it is vital that the suspension adjustments be carried out in the correct sequence, without any jumping to conclusions from premature Techstream measurements of pressures, and without skipping any steps and without getting the steps out of order.
Firstly, please ALWAYS start with the height readings, preferably hub-to-fender using a tape. Just take the readings, no adjustments until later as discussed below. Be sure that the vehicle is on a level surface, no driver, no passengers, no luggage or other contents, both fuel tanks full, steering straight ahead. The hub-to-fender height numbers are measured with the engine “OFF” and AHC “.OFF”.
Again, please DO NOT start by worrying too much about premature Techstream pressure readings – that just causes confusion.
Neutral pressure readings ONLY make sense when the heights are correct. If the vehicle is high, then the pressures will be high because the AHC system is carrying too much of the weight of the vehicle. If the heights are not correct then the pressure readings cannot be compared with the FSM specifications for Neutral Pressures and will not make sense to other IH8MUD Members when you ask questions.
Techstream and pressures are important later but please forget them for a few minutes until you have read the rest of this post.
As slus mentions in post #6, heights can be measured in different ways but if you use the hub-to-fender method you can compare with other IH8MUD Members and they can understand your measurements.
Also be aware that the pressure readings obtained using Techstream, or direct hydraulic readings, tell you NOTHING about the condition of the ‘globes’ (also called spheres). The ‘globes’ will be discussed later in this post.
The “HI/LO” test indicates the condition of the ‘globes’ (spheres) – as you mention, 14 graduations at AHC tank when ‘globes’ are new, 7 graduations means end of life of ‘globes’. As indicated in the FSM extract attached to my previous post, this test also only makes sense when heights are correct.
At the moment, your heights are not correct. This means that your Techstream pressure readings are kind of interesting but the readings are not conclusive. It also means that your “HI/LO” test (4 graduations) also is not conclusive.
Your heights also show that Front Left is low and Rear Right is high. At the moment, the vehicle is tilted downwards at the Front Left corner and upwards at the Rear Right corner. This is natural. It is exactly as expected. Remember that the vehicle is rigid. When the Front Left is raised, the Rear Right will be lowered which will mostly correct your situation. To illustrate, think of another rigid object like a book. Hold it in a fixed position at two diagonal corners. Now make one of the free corners move up. Observe that the remaining corner will move down. This is what you will see with your vehicle.
Your question was: “Does the front side to side height correction will help to the rear, cause I have an obvious difference at the back - driver's side sag?”
The answer is “YES – but driver’s side sag is not the problem” -- for the reasons given above and explained further below. After other things are corrected as described below, then it will be the right time to look again at rear hub-to-fender heights.
Toyota have assumed that the vehicle will remain in the same condition as manufactured. Provided that assumption remains true – no twists in the chassis – then if the two front corners are at the correct height after being correctly cross-levelled at the front, then only one height sensor is necessary at the rear and the rear heights will be the same on both sides -- provided the chassis is perfect. In the real world things are never perfect. Small differences and tolerances can arise. These are usually too small to worry about. If they are large, it is important to find the cause.
In your case, please first cross-level the front as described below using only the torsion bar adjusters, then see if you still have a DIFFERENCE between Right and Left at the rear which is large enough to worry about.
BEFORE ATTEMPTING TO ADJUST THE FINAL HEIGHTS OF THE VEHICLE AND BEFORE READING THE PRESSURES, cross-level the vehicle at the front. The final height at the rear will be considered later in this post.
What is the purpose of “cross-levelling”?
To explain ….
When the vehicle is on a level surface and with the front wheels pointing straight ahead, then the AHC system causes valves to open and hydraulically connects the Right Front and Left Front Damping Force Control Actuators (have a look at the diagrams in the attachments to my previous post – these are the devices to which the ‘globes’ are attached). This means that the AHC pressures in the Right Front and the Left Front are the same. It also means that the Right Front and Left Front of the AHC system are carrying EQUAL SHARES of the vehicle front weight. (By the way, when the front wheels are turned, the AHC system changes the internal valve positions and the AHC pressures in the Right Front and the Left Front ARE NOT the same. This why tests are done with the front wheels straight ahead).
In your situation, we know that the Right Front AHC and the Left Front AHC are at the same pressure and are carrying the same weight because that is how the system works.
If the Right Front height and Left Front height are different, as in your case, then the height difference is caused by the Right Front torsion bar and the Left Front torsion bar carrying DIFFERENT shares of the vehicle weight.
The AHC/TEMS system will not perform correctly and the vehicle may act strangely in this situation. This needs to be fixed by “cross-levelling”.
The purpose of “cross levelling” is to equalise the weight carried by the Right Front torsion bar and the Left Front torsion bar.
This is done with the engine “OFF” and the AHC “OFF” for safety and so that the AHC system does not counteract the adjustments being made.
Note that “cross-levelling” to correct the torsion bar loads CANNOT done by adjusting the Height Control Sensors. If this has been done wrongly or done in the wrong sequence during past work, it will have to be undone as it will have caused wild errors.
Both FIJK and slus have given good advice in earlier posts in this string and slus also has described how to make the “cross level” adjustments. This is usually done by turning the adjusters on both torsion bars in opposite directions until the Right Front hub-to-fender height and Left Front hub-to-fender height are equal.
It can help to move the vehicle (WITH AHC “OFF”) to ensure that the suspension has settled after adjustments, then re-adjust torsion bar adjusters again if necessary.
DO NOT WORRY IF BOTH HUB-TO-FENDER HEIGHTS THEN BECOME WRONG IN THIS STEP. THIS IS TO BE EXPECTED AND IT IS TEMPORARY.
PLEASE DO ONE THING AT A TIME AND IN THE RIGHT ORDER.
AT THIS POINT YOU JUST WANT THE FRONT LEFT AND FRONT RIGHT HEIGHTS TO BE EQUAL BECAUSE THE FIRST AIM IS TO EQUALISE THE WEIGHTS CARRIED BY THE TORSION BARS.
LATER, AFTER THE TORSION BAR LOADS ARE MADE EQUAL BY CROSS-LEVELLING, THE FRONT HEIGHTS ARE ADJUSTED TO CORRECT HEIGHT BY USING THE HEIGHT SENSOR ADJUSTERS.
When the “cross-levelling” is completed, then it is time to turn “ON” the engine and the AHC system. The AHC system will then set the vehicle heights according to instructions the AHC Electronic Control Unit (ECU) receives from the Height Control Sensors - Front Left, Front Right and Single Rear.
If previous work was not conducted in the above sequence, then previous adjustments of the Height Control Sensors will be wrong.
The vehicle heights will be wrong as well. It would not be surprising if all four corner heights are different after correct cross-levelling and all will need to be correctly adjusted.
So, after cross-levelling, the Height Control Sensors will have to be adjusted again to bring the vehicle to the correct hub-to-fender heights measured by tape, at all four corners. It may be difficult to get the Rear Left and Rear Right exactly right. Small differences of a few millimetres hub-to-fender measured by tape are acceptable. Your current difference of 2 centimetres is not acceptable. This will mostly be corrected when the cross-leveling is completed (firstly) and final height adjustments are made (secondly).
Except for cross-levelling, the torsion bars are NOT used to adjust vehicle height in a vehicle with AHC.
NOTE: You do need to be sure that all Height Control Sensors and their internal components are in good condition and operating properly. Otherwise they will be sending incorrect signals to the AHC ECU and cause both height and performance problems and malfunctions – and all you will achieve will be hours of endless frustration! If suspicious, take the Height Control Sensors off, disassemble, inspect, clean up, replace if necessary.
At last -- with the vehicle correctly cross-levelled, hub-to-fender heights correctly adjusted, and with vehicle on a level surface, no driver, no passengers, no luggage or other contents, both fuel tanks full, steering straight ahead --- NOW is the time to have a look at the AHC pressures using Techstream.
Any earlier pressure readings before cross-levelling and height adjustment are completed are NOT comparable with FSM specifications for Neutral Pressures.
Adjust front pressures if necessary, this time using EQUAL TURNS on BOTH torsion bars IN THE SAME DIRECTION until correct Front AHC pressure is reached, aiming at the mid-range of the FSM specification. When one complete turn is made to both torsion bar adjuster bolts, the pressure will change by about 0.2Mpa. This will NOT change the hub-to-fender heights because these heights are controlled by the Height Control Sensors, not by the torsion bars
AFTER completing Front AHC pressure adjustment into the correct pressure range using both torsion bar adjusters, and AFTER again checking the Rear hub-to-fender heights, check the Rear AHC pressure
As you have installed new OEM springs, reasonable Rear AHC pressure is expected PROVIDED THAT all of the above steps in this post have been completed inh the correct order. As you already know, there is no simple method of adjusting Rear AHC pressure. Spacers can be considered – but before installing them, it is best to complete all the above steps to be sure whether or not they are really necessary.
Also be aware that worn bushes in upper and lower rear control arms and worn ‘shock absorber’ bushes would not be a surprise in a 20 years old vehicle which has travelled 400,000 kilometres. The same could be said about bushes in the front of the vehicle – all worth inspecting closely with a torch and poking around, looking for crumbly or cracked bush material. Bushes in poor condition will have a bad effect on the ride. Replacement of bushes should be considered or possible consequences to ride quality must be accepted.
FINALLY, it is time to think about the condition of ‘globes’ (spheres) called ‘gas chambers’ in the Landcruiser Factory Service Manual (FSM).
With vehicle heights correct and with pressures correct, conduct the “HI/LO” test again. If the ‘globes’ are near new, expect close to 14 graduations at AHC tank. If the ‘globes’ are approaching 7 graduations it means end of life of ‘globes’ and all four ‘globes’ should be replaced.
You have asked: “In regard to the graduations - yes, I know that this is low, but they still keep good pressure - almost in spec. Does that mean anything or still could be shot?”
To repeat, please be aware that the AHC pressures tells NOTHING about the condition of the ‘globes’. There is no hydraulic reason why pressures would be different in a static test with good or bad ‘globes’ with the same vehicle at correct weight and correct height.
The AHC pressures give an idea of how much load is being carried by the AHC system, with the rest being carried by the torsion bars and springs – and that is all the pressures tell you.
My suspicion is that your ‘globes’ require replacement. The “HI/LO” test at correct height and correct pressure will confirm that or not. Even if the test under correct conditions shows recovery from the reported 4 graduations to 7 graduations, replacement of ‘globes’ still is indicated.
Changing ‘globes’ is not a difficult job – depressurise, remove old ‘globes’, install new ‘globes’, flush system, job done. Source OEM ‘globes’ from Toyota, Megazip, Partsouq, Amayama, eBay. Source alternatives from UK -- Pleiades or wtv-UK. ‘Globes’ can be expensive so it pays to shop around. Search the many IH8MUD links about ‘globes’ or ‘spheres’.
Last in this long post, we come to ride quality. This is governed by the Toyota Electronic Modulated Suspension (TEMS) system which works alongside the AHC system in your vehicle and is controlled by the same ECU. TEMS controls damping using many, many inputs from sensors all around the vehicle. These inputs include AHC pressures, vehicle speed, vehicle roll, pitch, yaw, steering angle, and others – see attachments provided previously.
Your post #1 says:
“(the vehicle) rides bouncy, springy - really don't know how to describe it. When I drive by speed bump the entire front of the car keeps going up and down for a while and takes some time to calm down. That makes the car uncontrollable and extremely uncomfortable for the passengers. The comfort - sport switch works, and it makes a significant change of the ride but doesn't help for the bounciness. Out of the town and highway, it is somehow better, but city driving is a nightmare, so I am looking for assistance”.
“Also, another question, at the current height - even far from what it should be, I am getting ~4 graduations. I know that lower than 7 marks mean worn spheres, but my pressure looks good and ride is not harsh - totally opposite, could call it springy/extremely soft/weak - does that still means that my spheres are shot?’
You have provided a very clear description of a suspension in which the torsion bars and springs are working but there is very little damping capacity. The suspension is not under control. It is not recommended to drive a vehicle in this condition. Please be very, very, very careful when it has to be driven.
Given two factors
  • the likelihood of a poor result from the “HI/LO” test (most likely less than 7 graduations), and,
  • your clear description of none or very little damping effect,
then by far the most likely cause of the lack of damping capacity you have described is ‘globes’ which have lost nitrogen gas pressure, and are past their end of life and require replacement.
You have mentioned that: “I am getting ~4 graduations. I know that lower than 7 marks mean worn spheres, but my pressure looks good”. If you are thinking that correct pressures suggest satisfactory ‘globes’, then that would be completely incorrect.
There are other more complicated and less likely possibilities such as faults in the Damping Force Control Actuators or the Control Valve assembly and possible problems with the AHC pump. However, you have not reported any Diagnostic Trouble Codes (DTC) from Techstream. You have reported that the AHC raises and lowers correctly and presumably you have timed the raising and lowering times and are satisfied these times are correct. A worn-out pump may raise the vehicle slowly and may not raise the vehicle fully. If this happens, there may be height errors.
Anyway, please accept apologies for what has turned into a very long post. The aim is to help you understand the AHC/TEMS system and some of the symptoms you have observed. Hopefully all this information will be of some help. This post should be read together with my previous post.
Hi Indro,
I do not mean to hijack Azi's thread on AHC, but your post above is possibly the most logical explanation of how to test and set up an AHC suspension system in a 100 series/LX 470. A+++ marks for you. As i am new to the LX 470 world i am learning piles about these cars at the moment and this forum in general is very helpful to me.
@IndroCruise, first thank you for your feedback!
WOW is all I could say...
I am just getting back from the car, where I tried everything you suggest and I have some news, good news!
This time, with AHC OFF, engine off and ignition off I managed to get equal measures from both sides. I had to crank the Driver Side TBar 3 turns and release the passenger side (same turns). Did some turns around the block and checked again. The front is now flat with everything off - 48,5CM from the center of the cap to the fender. Hooray!
BUT, what I noticed is...my Driver Side Torsion Bar is almost maxed out. There are like 1 or max 2 more turns 'till it reached its end. Should this be considered not ok?
Next, I start the engine and turned ON the AHC. Grabbed the tape and start measuring again. As you may guess - everything went totally out of spec. Driver Side was 49cm and the Passenger Side was 51cm in N.
I checked the Height Control Sensors, and they both were at the lowest possible point, with let's saying equal distance top to the bottom nut - weird to me. Everything equal, but still - different results. However, I slid up a bit the Driver Side sensor in the bracket and cranked clockwise the nut and at the passenger side, I turn the nut counterclockwise. With some play and repeat, I managed to get the car equal at N with Engine Running and AHC On - 50,1CM (19,75") at the tape!
BUT, the final success at the tape was at the cost of the total mess in the height sensors. My Driver Side Height Control Sensor is mounted at the highest point and the passenger mounted at the lowest, but I decided to leave it like that because with the engine on and AHC on the tape was showing exact 50,1CM (19,75") which is what we are all aiming for. So I jumped in the car and did some test driving around the block - oh well, no change in the ride. We are still going up and down...and when I stopped again and double-check the exact height in the front with the engine on and AHC on - it was changed! 49 Drivers Side 51 Passenger...
I still haven't connected the car to TechStream but I am really stuck now again. How am I suppose to correct the height while the engine is on? Should it take the computer next to the tire and keep an eye out on the data in TechStream while playing with the sensor or continue with the old way - play with the sensor, drive around the block, measure with tape?
In regard to the question about the DTC errors - I don't have any, not a single one.
Passed all health check tests successfully.
The steering wheel is also showing 0 degrees when it is pointing straight ahead.
Thank you once again for your support, patient, and skills!
I am located in Bulgaria, EU and here we have 0 mechanics familiar with AHC. I live in the capital of the country and went through every single well-known mechanic with no luck. The dealership is offering me to start with replacing everything and as they said - they cannot guarantee success. Oh, and the price is around $6k. For here - that's a lot of money!
Regards,
Azi
Hello Azi. Looks like you are in good hands, but I can comment on a couple of points where you might stumble. If my ramblings are already clear to you, then it might be useful for someone else. :)
The Left/Right lean (cross level) is adjusted with the torsion bars only. Whatever you do with the sensors will not affect the difference in height between left and right side. (Because the AHC is not designed to control L/R lean when stationary, only to minimise it in curves). When you see a difference in L/R lean after moving the car a bit, it is only because some stresses in the suspension parts have settled, or that the car is positioned slightly differently. Apart from torsion bar adjustments, the only thing that can make the car tilt L or R is weight, or a broken rear spring. As long as stationary, or driving straight, the AHC keeps the valves between left and right spheres open, i.e. same pressure exactly on left and right ahc sphere/shock (or ram, if you like).
When you are out of adjustment on the torsion bars, you have to undo it completely, take off the bar and put it back in rotated one notch on the splines. This is called re-indexing the TB, and is a quite a bit of work on an old (rusty?) car.
If you cannot get the sensors adjusted to give you the correct physical height, then something is wrong with them. Here's a list of what can be wrong:
- They are altered (sensor, bracket or linkage) to give a higher ride
- Sensor faulty, either worn carbon trace, worn slider, corrosion or otherwise bad connection
- Linkage bent, loose or stuck
- Arm bent or loose; or shaft stuck/hard to move
- Bracket bent or loose
The sensors are simple potentiometers, with a carbon trace across which a slider runs, giving a position signal. If you have the AHC set to position Lo and press N, the system will just apply more and more pressure until the sensor is at mid-travel, giving a reading of zero in techStream (or other tester). This is in principle all the height control does - adjust until zero. For the front sensors, the average between them is used for giving a zero value at level N, but if the difference is too great, the AHC will cut out and do nothing.
You can check the sensors according to the procedure in the FSM. A preliminary check could be to see that you have around 5 K Ohm across the sensor, and around 2.5 K on the slider-pin when in the middle position. (The actual resistance value is not that critical, as long as the ahc ecu can put its ca 5 volts across it and get a stable reading on the slider, which follows the movement of the shaft rotation accurately)
It is important that the sensors give a stable, continuous signal, with no dead spots, or varying resistance at the same position. Often they are worn out before the age of 200 k km. They often have a problem with ingress of water/humidity, which will kill them quickly.
Thought I could regurgitate one of my old posts from 2009 as well:
It is fairly easy to maintain the AHC sensors, particularly the rear one as it is easy to remove. When you have the sensor in your hand, with the lid off, you can see how simple it is. It consists of a body with a shaft through it, and a 3-pin connector at the back of the body. At the outer end of the shaft there is an arm which transfers the suspension movement. The inside end of the shaft has a little arm or rotor with two brass sliders/springs which provide the connection to the carbon resistance traces, which is on the inside of the lid of the sensor.
Then the important part: The connection between the 3-pin connector at the back, and the carbon traces in the lid, is provided by three little brass coil springs, which are just squeezed between the connector at the back, and the lid at the front. These springs corrode. Pull them out of their little holes and clean both the bottom of the holes (connects to the 3-pin connector) and the springs. You might need some contact cleaner and some emery paper.
The problem with the sensor is that the lid, with it's O-ring, doesn't seal well. And it looks like the lid bends slightly. So you have to seal it better. It would possibly be good to put an aluminium plate over the lid, to support it so that it doesn't bend, and then use longer screws.
Pictures:
This is the sensor on it's bracket, without the lid, in a vice. The part between the jaws is where the cable harness is attached. The part pointing straight up is where the bracket is fastened to the car body with two small bolts. At the bottom you see the arm which is connected to the leading arm of the rear suspension via a ball-joint linkage.
Pic #2 shows the "rotor" with it's two sliding springs, and the three holes for the springs. At the left side, towards the connector, next to the three holes, you see a bit of "pollution" in the o-ring groove, where moisture has made it's way in. It looks like the pressure of the three springs is to much for the lid, and makes it bend. You can also see traces of corrosion at the bottom of two of the holes. The liquid you see is a lubricating contact cleaner I have applied. It is normally dry.
This pic shows the lid with the carbon-traces, and the O-ring. To the right are the three contact springs, two of them a bit corroded at one end. That corrosion makes for a bad connection. Cleaning/polishing might help for a while, but a new sensor is better.
Hi @uHu and thank you for your input!
Simple to someone could be PITA for someone else!
I am not feeling confident to disconnect the sensors from the car and inspect it at home. I will leave that for later on if nothing else helps. Please don't get me wrong, but I am just not a mechanic. I'm trying to fix my car on my own because everyone in the family literally loves it and no one else could help. It is only me and the IH8MUD community in this battle.
In regard to the re-indexing of the TBars - this also doesn't sound like a thing that I could do on my own.
Regarding the broken spring - they are brand new. Black with purple, equal height right to left. The spacers from Australia just arrived today but I will not rush to fit them. I am a person who prefers everything to be "stock" rather than modified. When I get the height right and manage to measure the pressures correct, if needed I will fit them.
As an update to my previous post, I'd like to make a small update.
I tried some other combination with the sensors and nuts and managed to get the following measures*:
*ENGINE ON, AHC ON, N, CENTER HUB - FENDER
Front Left50cm
Front Right50cm
Rear Left52cm
Rear Right54,5cm
Attaching some photos to the sensors and the tape.
Please excuse my photography skills as well.
Later today will attach TechStream screenshot with the current position of the sensors.
EDIT: Attaching the TechStream results:
Everything is measured with a full tank to the top, empty trunk, no passengers/driver inside.
Regards,
Azi
Hmm. You can't fix it by just looking at it... Removing and opening the rear sensor is easier than changing the battery in your key.
One observation: The linkage for the rear doesn't look like that on my car. There is no screw adjuster like on the fronts, but a straight rod with a ball joint at each end.
Thanks, @uHu, good spot!!!
I just checked and you are absolutely correct. Looks like someone changed it with a front one in the past...
Never mind, just ordered the right linkage - 48906-60010.
...Start believing that this could be the root of all evil at the rear height. Fingers crossed!
What about the TechStream data?
How am I supposed to equal the difference at the FL / FR height of +2,6mm / -4,8mm?
Shall I play a bit with the torsions, slide the sensors up/down or turn clockwise/counterclockwise the screws (nut)?
Also, still not at the right height and not the time for the pressure, but this result of 5.6MPa ... does it mean that I have to rotate the TB adjuster counterclockwise equal turns, till I reach 6.9 (+/- 0.5)?
Regards,
Azi
Yes, for getting the front pressure down by adjusting TBs CCW.
For the sensor readings for the fronts, you adjust them a bit to get approx equal reading. If the height is now right, then you adjust one up and one down, the same tiny amount, to get them within 4-5 mm of each other.
I suppose the next step is to change the spheres?
Btw, you said that your coils springs are black and purple? Both a black and a purple paint spot on the same spring? That sounds like non-ahc springs -. What's the diameter of the spring steel? Or is the spring black with a purple spot, which would be an ahc spring?
Ok, I will do that tomorrow, as it is late evening now here.
4-5mm by turning the adjuster nut/screw or by sliding the sensor up/down in the "bracket"?
I really aim at this as the last step, cos that is the most expensive part of the whole system I guess.
Found a set of 4 on eBay for 569GBP, located in England, EU.
As far as I know, these are the ones that come from Pleiades, but someone else is selling them on eBay.
The springs are black with a purple spot mark - 2x 48231-6A770.
To be honest, the ones that I took of the car were black with pink marks, but I cannot return the ones I bought and also they don't offer pink marked.
New ones (purple) are ~30mm longer. Can't tell a thing about their firmness, but they did a significant change in the ride quality. Now the rear is feeling way more stable than before, especially over speed bumps.
Cheers,
Azi
Azi,
I hate to ask the obvious, but I recently chased down an issue like this on my LX. Are you absolutely positive you have no air trapped in the AHC fluid lines? I had to bleed out my accumulator a couple of times, then each line to the actuators a couple of times, one at a time recycling the fresh fluid back into the resevoir to keep it completely full to get the ride quality back.
I just may be worth the extra hour of effort at this point to eliminate variables. Good luck.
purple springs are good, better than the softer pink. Next one up is brown. IIRC it's 0.25 mm difference in thickness between them, and I think I saw a list of spring rates somewhere, was it in here?
At that price on ebay, it might be cheaper to get original spheres from partsouq or amayama. And did you contact Pleiades directly? They are very helpful.
For the front sensors' adjustment, it doesn't matter where you adjust. Just move one of them a mm and then see the result in techStream, and take it from there. The aim is to get both at the same value, but a couple of mm difference doesn't matter. ("Perfect" is the worst enemy of "Good"). And if you haven't used a flow filler on your garage floor, it wont be level enough for any mm-accuracy height readings or settings (maybe not for a cm accuracy even).
PS
From your questions, it looks like you haven't read enough of the ahc threads.
E.g. when it comes to ahc adjustment:
1- the torsion bars do two things, and two things only: Adjust the L/R lean, and adjust the pressure. (Of course the difference between the readings of the two front sensors will change if you adjust one of the torsion bars, but then the car wouldn't be level L/R anymore)
2 - the height sensors linkage adjusters do one thing only: Adjust the height for the rear, and adjust the height for the front (according to the combined setting/reading of the two fronts)
PPS
Many of the coil springs for non-ahc suspension have two colour dots, that's why I reacted a bit when I saw your "black with purple". But then again, you wouldn't have any rear pressure with non-ahc coils...
Azi,
Hi, @ramangain!
Definitely a good question, without being able to actually answer.
The flush of the previous fluid was performed at the dealership.
I hope that they know how to do a simple flush, but you know - hope dies last!
How can I check that, any obvious symptoms of air trapped in the system?
We have a problem here in Bulgaria with the fluid - it is not an easy task to find it locally, so you have to order it from abroad.
Adding the current situation with the COVID makes the delivery process even more fun!
PS
PPS
Hi again, @uHu!
I bought them from RoughTrax and so far so good - way better than the previous, which I believe never been changed.
These are the spheres that I managed to find on eBay. Price: 579GBP (569+10GBP Shipping)
I just received a reply from Pleiades. His price is: 540GBP (Shipping included)
In regard to the OEM ones, Amayama's price is 580GBP, but I am not sure about the VAT and import duty fee...Also, it doesn't show the shipping price. However, I submit an order and expect to be contacted soon.
Partsouq price for 1x 49141-60010 is $320 and for 1x 49151-60010 is $345 ... that makes $1330 way more than the others.
What I am afraid the most is, in case I replace all 4 spheres and this doesn't solve the problem with the bouncy ride.
That would be a total waste of money...
Regards,
Azi
UPDATE:
After a whole weekend spent in trying to fix the issues with the height, today I found the car like this:
Not a single DTC in TechStream.
When I try to go in Lo mode, nothing changes. Hi is not working.
Now the ride is brutal harsh...so here comes my idea that changing the spheres may be not the only thing required and may change nothing, but my bank account.
Should I start with replacing the rear height control sensor?
