I'd take some advice on changing out a radiator on my '98. I took a look - doesn't seem to bad. Just wondering on a couple of things:
- Does the fan have to come off to get the shroud off?
- Do the lines for the trans fluid need to be undone to remove the radiator?
- Any other "difficulties" I need to be aware of specific to remove/replacing radiator?
- How much coolant do I need?
- At 200k are there any other hoses to replace other than the top and bottom radiator hoses?
Thanks
Haven't pulled the radiator myself but just recently did the TB service (requires disconnecting at least the radiator hoses and reservoir and fan and fan shroud etc). Which brings me to ask - have you done your 180k miles timing belt? If not, this would be a good time to do it since removing the radiator and fan and shroud are part of the job anyway. Also, take a look at the fan bracket bearing and the fan clutch - those are items that at such high mileage may need replacement and you're right in there anyway.
- according to the FSM you do need to remove the fan and shroud. From personal experience I can't imagine removing the shroud without the fan. However in theory I guess I could see removing the radiator without removing the shroud or fan?
- The transmission cooler lines do need to be disconnected from the radiator.
- Capacity according to the FSM is ~16quarts. I think I only needed ~3 Gallons to refill.
- As far as other hoses to replace I would inspect the other hoses to see what condition they are in and replace as needed. Or if you're a perfectionist you could order them all up and replace them if the price is within your pain threshold.
- (tip 1) Personally I find the purpose made hose clamp pliers very helpful, and I find pick tools to be handy in getting the hoses off.
- (tip 2) To get the hoses back on, some people use soapy water, dielectric grease, spit. I know some people also use grease but that apparently is not recommended for numerous reasons - I don't know if dielectric grease is better, but soapy water or spit should do and would have no ill effects.
- (tip 3) Obvious, but I'll mention it. If you're disconnecting the transmission cooler lines, make sure to refill properly (i.e. following FSM instructions with vehicle level and fluid at coorect temperature when measuring for full) afterwards.
- (tip 4) Another potential tip, they do sell (radiator) hose clamps that you could consider using to minimize the amount of fluids you need to replace. Alternatively, if the tranny fluid and coolant haven't been replaced recently you could take this opportunity to do a thorough drain and refill to get fresh fluids in there.
- (tip 5) Oh, for tips removing the fan.. the fan moves while you're trying to use a wrench to loosen (and tighten) the nuts. I used a second wrench in the opposite direction on the next nut over - this works perfect for all but the last one (still works for last but not as perfect since you need to retighten one of the others for leverage.. but it comes loose easier the second time since it wasn't fully tightened). Many use an old drive belt or something similar to hold the fan in place. There are other tricks but a second wrench worked for me. Also, for removing the fan and shroud - I think a lot of people pull out both together for ease/convenience. Personally I was able to get out the fan and then the shroud separately but I've seen others say pulling out both together is easier.
