Right, I see engnbldr says leave the exhaust alone. The engine needs some back pressure for low end power. 4x4Wire's TrailTalk Forums: need a lil more power any suggestions? OK, that simplifies things.
Ive heard thats a myth on gassers....
Ive heard thats a myth on gassers....![]()
It isn't. Calling it back pressure really isn't right. What is needed is the proper sizing of the exhaust pipe so exhaust gas flow speed is maintained. With high enough exhaust gas flow speeds in the manifold, a small amount of vacuum is generated behind the previous exhaust puff from the cylinder. This all comes from conservation of momentum, a fundamental law of nature. That small vacuum helps pull out the next exhaust puff. Make the exhaust pipe to large and the exhaust gas flow speed is not there to generate the vacuum so the exhaust gas flow stalls and performance suffers because the next puff of exhaust has to push the previous one out of the way. The energy in the exhaust gases varies by the square of its speed, so keeping it moving faster allows for greater vacuum to be generated. Of course this is all exhaust gas volume dependent which is dependent on RPM. An exhaust system that provides optimal low RPM power is usually to small for optimal high RPM power because it starts to provide to much resistance, "back pressure", at greater flow volumes. Engnbldr didn't mention it, but I bet adding 1/4" pipe diameter after the catalytic converter and 1/2" after the muffler would likely free up a couple ponies, but that is it. It would only be worth it when the exhaust system needs replacement. Is it worth the extra cost? I'd have to have somebody custom bend the pipes. On the other hand I can order stock parts, have them shipped to the farm, and do the exhaust system repair myself.![]()
You heard incorrectly.
Most Harley exhausts do more damage to the usable power band than good.
As much as Harleys have anything that could be called a power band.
ROFLMFAO!!!Fixed it:
