I was up at Rob Lassmans the other day with my 81 and we adjusted the fuel setting, turning the screw out close to half a turn (Rob correct me if I am wrong), and the immediate effect on the black smoke was amazing. Turbo was running great and no change with the fuel setting change. It was still stock from with the little clip on it so it did not look like it had been adjusted.
I also seemed to get an immediate improvement in fuel economy. I am now getting around 600km per tank so likely around 650 with the 255/86/16's on the truck.
Anyway, if you want your trucks working top notch, i would suggest seeing Rob. He is terrific. And he does not mind you poking around with him and learning at the same time.
btw, i had the injectors cleaned, oil changed, clean air filter....so it was the fuel setting..........
thanks and anyone who wants information on this issue just contact me back
Dave
Dave
