To All,
I own a 97 model with 110,000 miles on the ODO (Stock no modifications).
Lately in order to keep the truck tracking straight I have to tilt the steering wheel 20-25 degrees to the left (pulls to the right if the steering wheel dead center, also have a slight tire wear showing on the right front tire)
Note: The steering wheel is tilted to the left by 10-15 degrees if left alone as well.
I know the only adjustment for alignment is TOE on the 80......adjusting the front rod for wheel centering will have no affect on the alignment with the exception of centering the steering wheel....How can I do this ? and is it possible that someone provides some pictures of the Front Rod that needs to be adjusted so I know which one to tackle.
Also I will be checking the TOE and adjust it accordingly and if I am not mistaken it is the one that is located behind the front axle ?? am I correct ?
Any help you provide is much appreciated.
Thanks
Al
Thanks
Al
