Progress report,
Back on this after my trip, (many Coho Salmon in my freezer
) I drilled up the chunk of aluminum, made provisions for feet (made form a relatively low heat conductance metal) that will raise the chunk off the bottom of the pot, this will insulate the element and allow oil to circulate under it. Goal here is to try to have the thermistor and thermocouple read the same temperatures by minimizing uneven heating in the chunk.
On top it has a spot milled for a thermistor, I did not want to try to track down a metric tap for it so instead it is milled for the two diameters of the thermistor and made a clamp to ensure good contact to the aluminum for both heat and as a ground for the thermistor. Three 1/8" holes are drilled for thermocouples at varying depths and a threaded hole for a ground connection.
Also did the boiling water calibration test for the digital thermometer,
I found out my digital thermometer looses the tenths past 199.9, so I don’t get sub degree resolution of boiling point in Fahrenheit but I do in Celsius
Boiling readings were
210F steady
98.8 C to 99.0 C.
Both thermocouples read the same thing at the same time (down to the tenths) , I think the bobbling in the C range was due to convection currents in the water,
Intellicast.com reported 29.99 and rising but that was 1.5 hours behind so no good
All three airports reported 30.23
At 30.23 and 840’ water should boil at 211.0 F / 99.4 C
I’ll call that <1 degree error and good enough for our purposes
I have two days off hope to squeeze in the rest of the test bed build (not much left) here shortly,
Sorry for the delay but could not miss this.
