ok
talked to the electronics guy again
to get a steady 12 volt input you can either use a zener diode and resister or an ic regulator. The zenor system will handle 100 milliamps or 1 watt and has a 12.5 minimum input. With lower voltage it flows through the actual voltage so you would not see any variation until current dropped well below 12 volts at which point it would not matter. To make one you need a test board, a box, a zenor diode and a resister (he guessed about 470 ohms) and a soldering iron. the little box would then have 2 inputs and outputs in line on the power and ground wires within a couple of feet of the gauge.
the ic regulator is the same kind of cost would handle 1.5 amps but has a minimum power requirement of 14 volts (2 volt differential). You can order one with a lower differential for more dough but my guy does not stock them. Otherwise same deal. solder one up using a test board and box.
The zener diode sounds like the way to go depending on the maximum current draw. I went back to the photos of your fluke meter and saw it went up to 956 vdc with the needle buried at the top of the red at 259 degrees but I am not sure what voltage scale that is?
Raventai, this guy will basically design it for me if you can provide the raw data.
total price of zener box regulator setup would be under C$10
