adding a temp gauge to my fj55
Mill Valley, CA
I'd like to have an actual temp gauge in addition to the stock temp gauge in my 72 fj55. What are the simplest option(s_ to add an addl temp sender? Ive seen a 2f thermostat housing that has a threaded plug that may work but, I was thinking maybe the stock sender port and somehow split the sender wire to 2 devices? not sure there another threaded hole in the top of the head that's available for an addl sender. Thoughts?
There are 2 threaded (1/2"NPT) holes in the top of my head, I kept 1 for the stock sender and one for the Autometer sender.
In the past I have also used the extra port on a oil-cooler capable water pump for a temp sender...
Thanks ,that makes it easy. Now I'll need to figure out where to wire into the ignition power source ::confused:....
