Added 100 amp panel to my electrical system
Littleton, Co
I used some Klixon resettable aircraft circuit breakers and a couple of 50A relays to add 100A of capacity to my electrical system.
I needed to supply the larger (60 p.s.i.) fuel pump, the electric water pump and the two 30A cooling fans.
I installed it in a sub-panel that I mounted under the pilot side of the dash.
I hid it in the small, useless speaker spot.
Did you really need all that in the cabin instead of in the engine compartment?
Yes.
1) the Klixons are not waterproof (the relays are);
2) allows me to pull out the circuit breaker to the fuel pump for security;
3) allows me to pull circuit breaker for the fans when going through water;
4) allows me to hide them.
