Wanted Accelerator/Throttle Cable for HJ61/HJ60 (12H-T/2H Engine)
Libreville, Gabon
The accelerator cable on my HJ61 (12H-T powered) now sucks. I need a replacement one in good condition.
I read the same cable in an HJ60 (2H powered) will also be for an HJ61.
Thank you in advance.
Regards
Regards
you need like way more TECH details matter details posted here
- modle year truck
- modle specifically hj61 or HJ60 ?
- what motor exacty
these accelerator cables ain't just a generic what ever item
there very specific
post above now and report back
if one exists still on globe i can make it mine asap
matt
- modle year truck
- what motor exacty
there very specific
matt
Hello thanks.
I am primarily in need of an accelerator cable for:
- Toyota Land Cruiser HJ61
- Year 1987
- Engine 12H-T
*LHD (if that matters at all)
Secondly, an accelerator cable for:
- Toyota Land Cruiser HJ60
- Year 1983
- Engine 2H-
Regards
Hello thanks.
- Year 1987
- Engine 12H-T
- Year 1983
- Engine 2H-
Regards
I’ve done a few conversions putting 12HT’s into LHD 60’s. I have used the FZJ80 throttle cables. this may be an option on a factory 61.
Hello thanks.
- Year 1987
- Engine 12H-T
- Year 1983
- Engine 2H-
Regards
let me know if you still need my help before i take all the time to find you the correct parts for you
thanks ,
i don't know any tech in regards to this other mentioned cables above ?
i only know what does work for correctly for you by the book .and microfiche ...
thanks matt
that being said ,
i DO have NOS
3F carb accelerator cables , folks have purchased them for various other 60 61 and 62 series hybrid and DIESEL unicorn applications
then cables ends are same similar in kind and the length also met there various needs
Thanks for your updates.
I'd appreciate it if I can get a cable that will do a direct replacement for my current accelerator cable (12H-T). If you can get that, it'll be great!
As for the 3F carb accelerator cable, I need to check that with my mechanics (and some research)
Nevertheless, how much do you see the 3F carb accelerator cable?
Regards
