All refrigerant was mysteriously gone after safelite replaced the windshield. No leaks, and no previous problems. I think an employee may have been upset that I required rivets, and wouldn’t let them use screws.
I’ve tested and recharged the system (vacuum pump and gauges) Low side pressure is about 25 psi, High side is about 205 psi. Vent temperature around 45 degrees. Ambient temperature in mid 80s. Humidity high 60s.
I don’t have any bubbles in the sight glass at shutdown. Do I need to remove some refrigerant with pressures in spec?
Thanks
Thanks
