Has anybody had this problem? We replaced the expansion valve, drier, condenser (original damaged in accident at some point). The new expansion valve came with a "conical" shaped piece that only seemed to fit one way into the valve but the cone shaped part faces "outward" which would makes the freon (converted to a134) not funnel into the valve. That description was awkward! The old valve had this restriction (funnel) pointed down into the valve. The new valve fitting seems to only install pointing outward. Seems wrong and may be why the pressure is so high on the low side and low on the high side.
Any thoughts?
Any thoughts?
