I have been searching and reading threads for hours and days and still have a few questions, so blast me for the search comments if necessary or direct me to some good answers. I may loose my job with all the time I spend reading on this site.
First, here is the story: I purchase my 97 in november 2007 and was told by the owner that the air did not work. Owner showed me the stealership quote of $500 to repair a small leak in the expansion valve which he did not do. Mind you this is before he shows me the recipt for a stealership repairs a year earlier for $600 for schrader valves, dryer, o-rings and recharge. So I say, reduce the price I offered an additinal $500 which he does. Everything good, now doing preventive maint and mods over the last 4 months totaling $4000. This includes lift, bumper, hoses, rotors, pads, misc parts etc. most of which i am doing myself when possible. Easy to convice manegement
since we negotiated the asking price down and the sell of the fj40 will fund the mods. Now Its getting hot in so cal so after much reading I decide to get a leak check from a good local air shop and explain the prior repairs and my newly gained knowledge from this site.
Second, this brings me to today: I get a call from the shop saying he added 1.5 lbs to check for leaks and he starts in the cabin with sniffer, no leaks detected even on sensetive setting. So he opens the hood and bam sniffer goes off and he eventually finds a strong reading by the compressor which appers to be leaking from the main seal near the back of the compressor. he says he lost .5 lbs in 1 hour before evacuating the system with a large leak from the compressor. He also states that whoever did the last work on the system evacuated the system and left it under vacumm and was quoting only the expansion valve since it is a common replacement part and they were likley fishing for more $ once they began the repair. He reserched prices for parts and suggests new compressor, expansion valve, shorter dryer for new short bus bumper, and pressure switch while we are at it. Total estimated cost $1400.
So I ask 20 minutes of question (with my knowledge from this site) about the system which he gladly answers and appently correctly (from my knowledge from this site) so I believe him since he says I could do some of the work myself and bring back for a recharge. Of course without warrante for the parts I install. He suggests that if I am going to replace the compressor I use a new denso, and since i would need to spend $500 on this part alone it is advisable to replace the other parts mentioned at 5-6 hours of labor. Therefoe the $1400 price. selling this to manegment would be hard.
Fianlly, this brings me to my questions:
1. What would you do in this situation keeping in mind I have a new 5 week old girl and limited
's and time to work on it?
2. Would you source the parts and install them yourself?
3. Should I buy new or remanufactured parts when possible?
4. Does the steelership leaking expansion valve seem correct, do they leak?
5. Would a leak like this hold a vacuum?
6. Can you repair a seal in the compressor or is a new one needed or recommended?
7. Does $700 for parts-charge and 5-6 hours labor at $700 seem correct?
Answers to any of these is appreciated. Either way I am heading into the so cal desert this week for a run. Upper coyote canyon for those of you in san diego if interested. damn the heat to hell
