Ok, I'm stuck on an issue and think it may be a clogged expansion valve but before I jump on that I wanted a second opinion.
I flushed the condenser,lines, evaporator, replaced the pump, receiver/drier, o-rings, and the expansion valve. After evacuating the system when I go to charge on the high side it won't take more than 1/2can and only gets to about 75-80psi. No pressure on the low side. The high side gets enough for the clutch to engage but pressure won't build and still nothing on the low side. The fsm has me thinking that it is a clogged expansion valve but it is new and a royal pain to get to. Any thoughts? Why won't the high pressure side build up even with a clogged valve?
