After mangling my AC dryer lines this summer I worked with Mot to get a JDM solution to relocate the AC dryer into the engine compartment. Thanks Mot
This is one of those mods you just love - tight spaces to work in yet everything fits perfectly with exactly the result you wanted. The kit is basically hard lines to route into the engine bay in front of the battery plus a bracket that mounts up to existing holes.
The only difficulty was sensor lines that were too short and had to be spliced since the kit relocates the mount to the hard lines (and this was simple to do), and you have to be careful to tighten everything to prevent leaking. The hard lines have a bunch of adjustment that allows you to rotate the hard lines to get them in the right position, and you have very little room to work with to get everything tight. Patience is the key here.
End result - no more low hanging AC dryer and nice cold AC
