For my Isuzu diesel swap, I replaced the original FJ60 AC amplifier with one from an FJ62, as the diesel doesnt have/need a tach sensor and the 62 amplifier doesnt need one to operate. With the system all connected, the clutch is still not engaging. On further diagnosis I have found:
Things that make sense:
- signal from AC switch at pin 2 is good at 12V.
- signal from pressure switch at pin 3 is good at 12V
- pins 5 and 6 are confirmed connected to ground (I actually removed pin 5 for my application, but that will not affect anything here)
- thermistor is measuring about 1.2k or 1.3k (I cant remember which) when the vehicle is off. measured between pin8/9 and 6 of the connector to the amplifier
- wire from pin 7 to compressor is a short circuit (aka is connected and true)
- ignition signal is at 12V
- I can force the relay to switch - relay works
Things that don't make sense:
- pin 7 to compressor clutch is at 0V.
- Voltage on the base of the transistor that is acting as a switch for the relay is at 0V. This NPN transistor needs a "high" voltage to turn "on" and then connect its collector and emitter together to cause the relay to switch
- Voltage at output of Toshiba pins 4 and 6 is 0.15V.
Things to note but I do not know if they are correct or not:
- The voltage at the Toshiba pin3 side of the 110k resistor at connector pin 9 is 0V. This seems like it should not be, but I dont know why I think that.
- Voltage at the Toshiba side of the 1.1k resistor near connector pin 8 is at 2.02V.
- Other side of 300 ohm resistor in series with connector pin 2 is 5.86V
- Voltage at Toshiba pin 1 is 2.96V
Questions that I have:
- Issue is either the opamp or the thermistor (but I could reasonable be convinced otherwise too).
- Why would the opamp not be outputting a high voltage from its pins 4 and 6?
- Has anyone ever had an issue with the Toshiba opamp going bad? The Toshiba part looks to be an ASIC and there are no datasheets on it. I might be able to find one at the junkyard.
- Could the thermistor be the issue?
Does anyone have any thoughts about what could be going wrong? I could put a jumper between pins 2 (AC switch) and 7 (compressor clutch) but I would rather not, as I dont want to freeze my evaporator.
On a side note, I think that the opamp is actually a dual or triple comparator.
thanks for the help!
Dazed
Dazed
