So I guess I joined the abs club. 1993 just did a 2” lift. im having abs light on when the truck move. I check ohm at the front sensor and rear sensor, check continuity on the harness for posible short, I check ac volt at the rear getting voltage when I spinning the tires. I removed the sensor in the back I spray brake cleaner and blow with my compressor. Now the light goes and comes back randomly. Im getting abs pulses at very low speed. Im was able to to pull the code I believe is 31 and 33 the light goes away when I shutdown the truck. I was forced to do the paper clip trick with the truck still running otherwise I won’t have any code. Any help will be appreciated. Also if anyone has a sensor for sale?
