I have an A343F transmission (120k miles or so) that I will be installing with a new engine next month. (LX450).
I’m planning to do the following:
- Replace output seal (90311-48016)
- Replace input seal (90311-38020)
- Replace shift solenoids (x2 85420-21090 and x1 35250-50030)
- Replace filter (35330-60020)
- check valve body torque
- Increase line pressure from Medium to High position
- Reseal pan with 1281 FIPG
- Reseal rear extension housing with 1281 FIPG
- Replace ATF inlet/outlet union O rings (x2 90301-11006)
- Top off with fresh fluid
Is there anything else I should consider doing? Has anyone removed the rear extension housing to reseal the FIPG? It looks pretty basic, 6 bolts on back.
I’ll be documenting here. I degreased the exterior yesterday, it was a combination of old engine oil, dirt, and undercoating.
