A pillar waterproofing (1 Viewer)
^ and make sure the rivets holding the trims surrounding the windshields on both A-pillars are also sealed.
You’ve told us the symptom. The above are solutions to a range of problems, but we don’t know what problem you have. Where is the water coming from?
4 likely options - sunroof drains, windshield side trim, windshield seal (rare), and if you’re just seeing water in footwell, could also be around hvac/blower. Figure out which is your problem, and solution will be recommended.
