Brian Macgyver said:I suggest going to the simple. That is the technician's first trick. Unplug the compressor wire and hook a jumper wire. Start the engine and touch the jumper to the battery + direct. Does the compressor kick in? If not, the clutch coil is gone. If so, work your way thru the system step by step until you find the problem. Jumper the output side of each relay and switch until you find the fault. That's how we do it in a shop.
CUSTOMER STATES A.C. IS BLOWING WARM AIR, A.C. LIGHT NOT FLASHING – RECHARGE SYSTEM, ADD DYE, AND INSPECT FOR LEAKS
INSPECTED VEHICLE, VERIFIED CONCERN, FOUND SYSTEM UNDERCHARGED SLIGHTLY, CHARGED SYSTEM, STILL WARM, NO LEAKS DETECTED WITH DYE;
FOUND A.C. CLUTCH NOT KICKING ON – ALL LINE PRESSURES NORMAL; FUSES, THERMISTOR, DUAL PRESSURE SWITCH, WATER TEMP SWITCH AND SENSOR, COMPRESSOR RELAY ALL OK;
SUSPECT POOR COOLANT TEMP CUT RELAY (BEHIND PASSENGER SRS AIRBAG); TESTED OK;
VERIFIED GOOD CONTINUITY ON ALL HARNESSES AND GROUNDS; OK;
CONTINUED TESTING ALL APPLICABLE SENSORS/SWITCHES/RELAYS, ALL OK;
REMOVED CONSOLE TO TEST AMPLIFIERS, CONNECTORS, AT A.C. AMP. NOT READING PROPERLY, SUSPECT A.C. AMPLIFIER ISSUE, CALLED DIFFERENT LEXUS SERVICE CENTERS, INQUIRED ABOUT CONCERN – NO OTHER REPORTED CASES WITH THESE CIRCUMSTANCES;
RECOMMEND TAKING VEHICLE TO LEXUS SERVICE CENTER TO CONTINUE DIAGNOSITCS.
RavenTai said:Doug are you interested in fixing this yourself?
RavenTai said:do you have a multimeter ? familiar with the basics of its use?
