A/C Blower motor R&R
Scottsdale
FSM says that the whole dash has to come out. Is that so for those that have done it, and is it a royal PITA or not too bad?
No need to remove dash if you are referring to this blower fan. Remove total of 5 screws according to the FSM.
A squirrel from the looks of it. :p
Fsm for '96-7 says remove the whole dash. And yeah, that looks like it actually swallowed a squirrel
If you need to remove the dash let me know. My shop is air conditioned and I just completed a dash swap on my LX so how to do it is pretty fresh in my mind.
FRONT BLOWER MOTOR REMOVAL
1. REMOVE COWL SIDE TRIM RH
2. REMOVE ECM
3. REMOVE LOWER COVER
(a) Remove the 2 screws.
(b) Release the 2 claw and remove the cover then disconnect the control link.
4. REMOVE BLOWER MOTOR
(a) Disconnect the connector.
(b) Remove the 3 screws and blower motor.
I found the section that talks about dash removal, but that is for "blower unit" removal. I think that is for the whole assembly. However, I remember reading posts in the 80 forum that dash removal is not needed for blower assembly removal.
Passenger kick panel is the plastic that runs along the door bottom up to and under the glovebox on the pass side.
Both of mine had the tabs broken off where they connect to the firewall/footwell so be careful not to break yours if you decide to remove it.
yes, those tabs like to break
