Looking at a 1999 LX470 with 185,000 miles on it.
Found this service history on it:
COMPLETE C.S. HEAR NOISE FROM BELT AND NOW CAR WILL NOT START - 157837 500 UPON INSPECTION FOUND TIMING BELT OFF TIME AND SHREDDED AS WELL AND BOTH SERPENTINE BELT AND TIMING BELT TENSIONERS SEIZED AND CAMSHAFT POSITION SENSOR DAMAGED FROM TIMING BELT R AND R CRANK TIMING BELT PULLEY BOTH BELT TENSIONERS BOTH BELTS AND PERFORM VISUAL VEHICLE INSPECTION AND REPORT - 157837 miles PERFORMED VEHICLE INSPECTION.
There is quite a bit of good service history for this vehicle but apparently.... the timing belt had never been replaced (Toyota recommends every 90K miles).
The 'repair' (after the fact) seems appropriate...all affected parts replaced and the engine now has an additional 30k on it since the repair.
Question: Would you consider this engine to be O.K. at this point or is it an automatic No-go?
I don't see that the water pump was replaced at the same time, which should have been done while they were in there. Also an aftermarket starter has been installed at 65K
Thank you for any advice. I am not too familiar with the 2UZ engine.
Flint.
Flint.
