98 toyota securikey+
Status
Not open for further replies.
Hello,
I am looking to remove a securikey+ system from a 98 toyota rav4.
Is there a manual that explains this?
thanks
Bob
I assume you're talking about an add-on starter interrupter system. These are fairly easy to remove, everything that doesn't look factory will need to come out. The only tricky part is disconnecting the wire from the ignition switch to the starter relay. With an A/T, this should be large red wire, M/T has a black wire to the clutch start switch. Cut the alarm wires loose from this then connect the factory wire back together, with a butt connector or solder & heat shrink.:D
Status
