For Sale 97 LX450 Triple locked moderately built. Memphis,tn
256k miles, triple locked, new tires, new shocks, 2"iron man lift with 1.25" spacers. 3.25" total lift. new stabilizer, one year old ARB bumper, rock sliders, snorkel,full roof rack, rear swing out carrier, rear auxiliary power and USB. 150amp relay controlling auxiliary stuff with separate fuse block.7pin mod, added center diff switch, all lockers work flawlessly. New 2.2kw starter. Also have the jump seats in storage
I've owned it for almost two years, always runs great I've just been catching up all the maintenance and building it up as I go. I drive it 60miles a day. Zero rust
Minor issues:
Of course the front seats are worn but have good fitting covers,
Check engine light is on, for egr modulator (common problem) doesn't cause any issues.
Front left axle seal leaks, parts are in the mail, will be fixed soon.
Engine weeps a little oil, two drops over night. Believe it's the valve cover gasket which I have, just waiting on a warm weekend.
Going to start asking $10,500 after I fix the axle seal this weekend. Without winch.
Located in Memphis,TN
$10500 OBO
BUMP. Front seal, oil pump seal, distributor o-ring, power steering seals, PHH, radiator and heater control valve all replaced in the last year.
Nice truck! GLWS. Where did you get the rear tire carrier? I haven't seen one like that before.
Minor issues:
$10500 OBO
