97 LX450 / backfire / at start up
Jim S.
Sierra Vista, AZ
After engine cycles a couple of times for oil pressure and initially fires I get a loud pop. Had a 0420 code and replaced O2 sensors. I haven't had the code for several hundred miles. Thinking something something is up with the Cats, They are original and the truck has 130,xxx + on it. Truck is supercharged but I don't see that as an issue. No smog requirements in my part of Arizona and I could try an after market Cat, however I don't want to start throwing money at parts without a definitive cause.
Thoughts and advice appreciated.
Jim
Jim
Not sure I'd think of the cat(s) first hand; I'd suspect something like too much unburned fuel, which is then combusting either in the header or in the cat(s)?
I was thinking that too, Possible bad injector? Plug ,wires and distributor cap were replaced a couple of years back and we don't put a lot of miles on it.
Reset fuel trims if possible, or pull ECU fuse for a spell if you can’t using scan tool. Some will, some scan tools won’t. After that start it cold and watch the short term fuel trims and also the long term fuel trims and see if they’re happy. I suspect you’re running lean if you’re backfiring. Cats shouldn’t really be an issue my cats just passed CA smog with some of the best numbers I’ve seen on an old rig and they’re original with 195k on the clock. Does your super charger have a extra injector on it?
Since I started to show my truck some love it's been one thing after another. For a while now it would have rough idle at times and reving the engine seemed to help. Yesterday out of the blue the truck started running erratically rpms dropping and had all I could do to get it back into the garage. Scanned the ECU and there was a miss fire cylinder #2. The truck's getting a new engine harness.
I used to have a vehicle that hated getting love, every time I did something nice for it ( excluding oil changes ) the thing would always be pissy…. New rims , boom head gasket.. new suspension boom! distributer goes out rear LCAs , alternator time… on and on.
