I am trying to determine IF the part number is printed/ stamped on the Denso o2
sensors I just received? or if there is a way to figure out part # from what is printed on the sensor, because it does not match the part number ordered.
Previously had P0135 and P0141.
Parts ordered:
Denso
234-4153 (downstream)
234-4157 (upstream)
I purchased 2 sensors, 234-4153 (downstream) and 234-4157 (upstream) for my 97 Toyota
Land Cruiser. I installed 234-4153 (downstream) and had a hard time with a seized nut on 234-4157 (upstream) and did not install. So I cleared the codes and ran the car to work, where I figured, I'd spend a little more time and replace 234-4157, to have 2 new sensors. CEL stayed off, with just one new sensor.
Installed the 2nd sensor and immediately CEL (P0135) came back on (P0141 stayed off).
The box shows the correct part number (234-4157) but I am not sure if it is the right part. It looks like
the old sensor, but I cannot find a part number on the actual sensor. Old sensors were different, one was a Denso (downstream) and one was a Bosch (upstream, I ended up putting it back on, and didn't grab the part #).
The sensor that seems to be not tripping any codes, has "Denso Assembled in USA" and "41790 01009" on the shaft, and "2571" on the flange.
On the sensor that came from the Denso 234-4157 box, it is printer "Denso Assembled in USA" and the only number is "41830 03S10". "2571" is printed on the flange.
Is this the right part? 234-4157?
Thank you for looking, Willis
Parts ordered:
Denso
234-4157 (upstream)
