- Joined
- Nov 1, 2005
- Threads
- 7
- Messages
- 14
Hey folks,
Got an electrical issue that I’m diagnosing and it’ll probably be a simple one to you old heads who’ve seen it all.
Tried to crank up my LC the other day and it was dead. I assumed someone didn’t close door all the way so put a charger on it, and cranked up after 10m. Ran my son around to the library close by but waited in the truck with it running. On the way home I noticed the battery gauge was a little bouncy, especially with the turn signal on.
Get back home and checked the voltage across the battery, reading anywhere from 12.5v to 14.2v with truck running. I disconnect the positive terminal, thinking that’s a good way to see if alternator is working and see around the same.
Leaving the battery disconnected I turn on the emergency blinkers and the truck turns off.
Seems like that means I’ve got a bad alternator. Could that also drain the battery when it’s turned off?
