Guys,
My stock '96 won't start, starter only clicks. The starter gear extends upon energizing the starter, but, the starter gear does not turn. I took starter to NAPA and it engaged and turned on their tester. I tried a rebuilt starter from a Denso rebuilder and it does the same thing on the vehicle. (Actually, I wrapped it in a towel,crammed it in place, hooked it up and jumped the ground by pinching a lead under an M12 cap screw in the starter base, to a bracket on the frame. Want to be able to return it unused!) I checked the resistance of the positive cable, from the battery terminal to the starter end of the cable, and it showed no appreciable drop in ohms. Checked the ground from the negative terminal to chassis, and it shows continuity, The battery was new in January, shows over 800CCA. Checked the fusible links in the engine compartment box, and the 50 and 60 amp both show continuity. The headlights are bright, all the dash lights illuminate,etc. I am going to check the fusible links coming off the positive battery terminals. I did check them for continuity, but, will check them for voltage drop.
Any help would be appreciated, I need this to tow to local MX track!!!!!
(Oh, and my wife would like it back,too.)
Philip
Philip
