Noah, I was getting about 13-14 on average before any mods after some tuning and maint. After all the maint and upgrades I am averaging 12-13 with all conditions of driving over about 6 months of fill ups using the same station mostly. I attribute this to making a bigger brick to cut the wind, added hundreds of pounds of weight, higher rolling resistance with tires etc. many theories. The only way to determine milage is to use the same type of gas nossle/pump, not top off and record actual fill up and milage over a long period of time and averaging. The metering of gas is not exact and even has disclamers on them at the pump. Some claim to get more gas in the cold weather do to expansion of gas with heat etc. The point at which the pump shuts off is not the same for all applications and is dermined differently for each system (although it is regulated to some extent). When I was in college this was proposed in a transportation class and found to vary by as much as 12% either way using a 20 gal average tank, the bigger the tank the lower the margin of error if I remeber correctly. Either way anywere from 10-15 seems resonable from what other seem to have reported from short time I have been on the forums. MOst consider it lucky to have over 15 it seems.
